Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Creating and Deploying an Application >
Configuring a Standard Interactivity Application to Run Without HTML Frames
To configure a standard interactivity application to run without HTML frames, you create a new web template and web page and use a predefined, frameless Siebel web template file. For more information, see About Standard Interactivity and High Interactivity.
  1. In Siebel Tools, lock the project for the Siebel application you must configure.
    For example, to configure Siebel eSales to run without HTML frames, choose the eSales project.
  2. In the Object Explorer, click Web Template.
  3. In the Web Templates list, create a new record using values from the following table.
    Property
    Value
    Name
    Enter any meaningful value. For example, Page Container Frameless.
    Project
    Choose the project you locked in Step 1.
    Type
    Web Page Template
    For more information, see About Siebel Web Templates.
  4. In the Object Explorer, expand the Web Template tree, and then click Web Template File.
  5. In the Web Template Files list, create a new record using values from the following table.
    Property
    Value
    Name
    Filename
    Enter one of the following values:
    • CCPageContainer_NoFrames.swt
    • dCCPageContainer_NoFrames.swt
  6. In the Object Explorer, click Web Page.
  7. In the Web Pages list, locate the container page for the Siebel application you are configuring.
    For example, CC Container Page (eSales). For more information, see About the Container Page.
  8. Right-click the container page you located in Step 7, and then click Copy Record.
  9. Create the new web page using values from the following table.
    Property
    Value
    Name
    Enter any meaningful value. For example, My Frameless Page Container.
    Project
    Web Template
    Choose the web template you created in Step 3. For example, Page Container Frameless.
Using a Predefined Template to Configure a Standard Interactivity Application to Run Without HTML Frames
You can use the predefined DotCom Page Container No Frames web template. This template includes the dCCPageContainer_NoFrames.swt file web template file.
To use a predefined template to configure a standard interactivity application to run without HTML frames
Configuring Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
