Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects > Configuring a Business Component Field >
Creating a New Business Component Field
You can create a new business component field. To create a new business component field
- Make sure you cannot reuse a business component field.
Before you create a new business component field, make sure a predefined field that meets your business requirements does not exist. For more information, see the following topics:
- In Siebel Tools, in the Object Explorer, click Business Component.
- In the Business Components list, locate the business component where you must add a field.
- In the Object Explorer, expand the Business Component tree, and then click Field.
- In the Fields list, add a new record, and then define properties for the new record.
You must not map multiple business component fields to the same column in a table. If you do this, then the SQL query fails because it attempts to access the same column twice in the same query. This configuration might cause an error message when Siebel CRM updates data, can cause problems with data integrity, and can lead to data loss for denormalized columns that reference the column.
- Compile and test your modifications.
For more information, see Using Siebel Tools.
