Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects > Configuring a Business Component Field >
Activating a Multi-Value Field
To refresh correctly in the master applet when the user closes the multi-value group applet, you must make sure the multi-value field is activated at the business component level. For example, if the Account Entry Applet displays the Active Login Name multi-value field through the Position multi-value link, then the Force Active property of the Active Login Name field in the Position business component must equal TRUE, or the Active Login Name field must be included in the Position MVG applet that Siebel CRM uses to maintain the account Sales Team. This situation is true even if the field is not visible. For more information, see, About the Multi-Value Field and Creating Multi-Value Groups and Multi-Value Group Applets. To activate a multi-value field
- Do one of the following:
- Set the Force Active property of the multi-value field to True.
- Include the multi-value field in the multi-value group applet.
- Compile and test your modifications.
For more information, see Using Siebel Tools.
