Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects >
Creating a Business Object
This topic describes how to create a business object. For more information, see Guidelines for Creating a Business Object. To create a business object
- In Siebel Tools, click Business Object in the Object Explorer.
- In the Business Objects list, create a new record using values from the following table.
Name |
Enter a name for the business object that is unique among business objects in the Siebel repository. Siebel CRM uses the name to reference the business object. |
Query List Business Component |
The default value is Query List. It identifies the business component that stores predefined queries for the business object. |
Primary Business Component |
You cannot define this property until after you define the business object components. |
- In the Object Explorer, expand the Business Object tree, and then click Business Object Component.
- In the Business Object Components list, create a new record using values from the following table.
Bus Comp |
Choose the business component that the business object references. |
Link |
Optional. Create a link relationship between two business components. |
- Repeat Step 4 for each business component that you must reference in the business object. You must define each of the following business components as a business object component:
- Any business component whose data displays in an applet on a view that references the business object
- Any business component whose data Siebel CRM exports in a report from a view that references the business object
- Define the Primary Business Component property, as described in Step 2.
