Configuring Siebel Business Applications > Configuring Tables >
Creating a Custom Index
This topic describes how to create a custom index. For more information, see Guidelines for Creating a Custom Index. To create a custom index
- In Siebel Tools, in the Object Explorer, click Table.
- In the Tables list, locate the table where you must add an index.
- In the Object Explorer, expand the Table tree, and then click Index.
- In the Indexes list, add a new index.
When you add a custom index to a table, Siebel Tools appends an _X to the index name. Do not use an index name that includes a word that is reserved on your server or client database. For more information, see Indexes of a Siebel Table and Siebel Object Types Reference.
- In the Object Explorer, expand the Index tree, and then click Index Column.
- In the Index Columns list, add a new record for each index column.
For more information, see Index Columns of an Index.
