Configuring Siebel Business Applications > Configuring Tables > Adding an Extension Column to a Base TableThis topic describes how to add an extension column to a base table. For more information, see Guidelines for Adding an Extension Column to a Base Table. CAUTION: Be extremely careful if you use a custom extension column to track a foreign key. If you use this configuration, then it is recommended that you consult with Oracle concerning the visibility rules that Siebel CRM applies to the foreign key table. To use Enterprise Integration Manager to load values into the column, you must set the Foreign Key Table Name property to NULL for that column. For information on creating a foreign key mapping for Enterprise Integration Manager, see About Interface Tables. To add an extension column to a base table
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
