Configuring Siebel Business Applications > Configuring Special-Purpose Applets > Configuring a File Attachment Applet > Configuring an Attachment TableAn attachment table is a type of table that provides the underlying data storage for the attachment business component. The attachment business component can support uses in addition to file engine functionality. The attachment table stores only file engine data. The user does not directly update the attachment table. Siebel CRM provides the user an empty attachment table. The user then uses drag and drop functionality or the browser dialog box in the corresponding file attachment applet to bring data into the empty table one file at a time. Table 55 describes required file columns in an attachment table. You must use the value described in Table 55 for the Name property. You are not required to use the value described in Table 55 for the User Name property. Various system columns that are not related to the file engine are present, such as CREATED, LAST_UPD_BY, and ROW_ID. If the table includes a file engine column, then you must make sure the File property in the corresponding table is TRUE. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
