Configuring Siebel Business Applications > Configuring ActiveX Controls >
Using ActiveX Methods and Events
An ActiveX control displays a set of methods and events that are provided with the control, for use with the Siebel high interactivity client. You can call a method from a script that you write in browser script that is attached to the control or to another object. You can program an event procedure to respond to events that the control generates. To use ActiveX methods and events
- Right-click the ActiveX control in the Applet Web Template Layout window, and then click the ActiveX Control Methods menu item.
Siebel Tools displays the ActiveX Control Methods dialog box. This dialog box lists the methods and the specified format for calling each method. It is for reference purposes only.
- Make a note of the method you must call, and then click Close.
- Do one of the following:
- Call the method from a script.
- Program the event procedure.
