Configuring Siebel Business Applications > Configuring ActiveX Controls > Process of Creating an ActiveX Control > Setting Properties for an ActiveX ControlThis task is a step in Process of Creating an ActiveX Control. An ActiveX control includes a set of properties that vary from control to control. To view or modify the properties of an ActiveX control, you can use the Properties window or activate the property sheet for the control. Using the Properties Window to Set the Properties of an ActiveX ControlYou can use the properties window to set the properties of an ActiveX control. To use the properties window to set the properties of an ActiveX control
Siebel Tools displays the modifications that you make to the native properties in the Applet Web Template Layout window, such as if you modify a text color or font property. Siebel Tools saves modifications that you make to the native properties with the applet, just as it does with Siebel properties. Using the Property Sheet to set the Properties of an ActiveX ControlYou can use the native property sheet of the ActiveX control to set properties. If you use the property sheet, then you can set only the properties of the ActiveX object. You cannot set properties of the predefined control. You must use the Properties window to set properties of the predefined control. To use the property sheet to set the properties of an ActiveX control |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
