Configuring Siebel Business Applications > Configuring ActiveX Controls > Process of Creating an ActiveX ControlTo create an ActiveX control for use with the Siebel high interactivity client, perform the following tasks:
An ActiveX control is a self-contained program that you can run in other programs. An ActiveX control typically registers itself in the Windows registry. You can incorporate any registered ActiveX control in the applet of a Siebel application that is deployed using high interactivity. You can use an ActiveX control to add some features to an applet, such as a slider, media player, and so on. You can also embed an entire application that you deploy as an ActiveX control. An ActiveX control works in most deployment environments. However, a development environment might or might not support an ActiveX control. For example, if you attempt to insert a Siebel ActiveX application control into an Excel worksheet, then an error similar to Cannot insert object results. Siebel CRM does not support some third-party ActiveX controls. For example, Microsoft Web Browser, Microsoft Rich Textbox, and CTreeView. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
