Configuring Siebel Business Applications > Configuring ActiveX Controls > Process of Creating an ActiveX Control >
Making an ActiveX Control Available
This task is a step in Process of Creating an ActiveX Control. To make an ActiveX control available for use, you must create DLL and class objects in Siebel Tools. These objects reference the CAB (cabinet) file that contains the control. To make an ActiveX control available
- Create a CAB file that contains the ActiveX control, or get access to a CAB file that contains the ActiveX control.
Microsoft provides some utilities that you can use for assistance.
- Copy the CAB file to the appropriate folder:
- If you deploy to a server environment, then copy the CAB file to the following folder:
ORACLE_HOME\SWEApp\public\language_code\applets
where:
- ORACLE_HOME is the full path to the Siebel CRM installation directory on the Siebel Web Server Extension.
- language_code is the three-letter code for the language. For example, ENU for U.S. English or JPN for Japanese.
- If you deploy to a CAB file on the Siebel client, then copy the CAB file to the following folder:
ORACLE_HOME\PUBLIC\language_code\applets
where:
- ORACLE_HOME is the full path to the Siebel client root directory.
- In Siebel Tools, click DLL in the Object Explorer.
- In the DLLs list, add a new record using values from the following table.
Name |
Enter a name for the DLL object. |
Project |
Choose a project. |
File Name |
Enter a file name and version that references the CAB file that contains the ActiveX control. For example: subman.cab#Version=7,0,0,0
Code or Class Id |
Enter the Class Id of the ActiveX control. For example: clsid:06314967-EECF-11D2-9D64-0000949887BE
- In the Object Explorer, click Class.
- In the Classes list, add a new record using values from the following table.
Name |
Enter a name for the class object. |
Project |
Choose the project you used in Step 4. |
DLL |
Choose the name of the DLL object you created in Step 4. |
Object Type |
ActiveX Control |
