Configuring Siebel Business Applications > Configuring Siebel Web Templates and Siebel Tags > Configuring Siebel Web Templates and Siebel Tags > Editing the Layout of a Web PageThe Web Page Object is the top level object in the Web hierarchy that Siebel CRM uses to create Web pages, such as the following: Similar to an applet or view, a Web page is associated with a Web template. Siebel CRM maps web page objects to placeholders in the template. The Web Page Editor allows you to view and edit web page objects. For more information, see Editing the Layout of a View. To edit the layout of a web page
Multiple Image Display in the Web Layout EditorThe layout editor might display multiple images because the template that the Web page references contains a conditional tag, such as swe:if or swe:case. The template content varies depending on if one of the conditions is met or is not met. For example, with a Page Container, the condition can determine whether Siebel CRM uses a CTI Java Applet or some other subtle or nonvisual difference. The layout editor displays the page as if all the conditions are true. This is useful if you must edit any of the pages. Only one condition is typically true in the Siebel client, so Siebel CRM does not display redundant images in the Siebel client. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
