Configuring Siebel Business Applications > Configuring Siebel Web Templates and Siebel Tags > Configuring Siebel Web Templates and Siebel Tags >
Adding Graphics to a Web Template
To improve the appearance or navigation of your Siebel application, you can create a GIF file and include a link to it from an HTML page. To add graphics to a web template
- Place your graphic files in the following directory:
public\lang\images directory
The Siebel Web Server Extension installer creates the public\lang\images directory when you install the SWSE. The Siebel client includes three directories for a Siebel application. These directories contain all the files that Siebel CRM uses, including the graphics files.
- Create a link to the graphic file from an HTML page.
- Compile and test your modifications.
For more information, see Using Siebel Tools.
