| Siebel CRM Configuring Siebel Open UI Siebel Innovation Pack 2015 E52417-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Roadmap for Customizing Siebel Open UI".
This topic describes how to configure the manifest for the recycle bin example. For more information, see "Configuring Manifests".
To configure the manifest for the recycle bin example
Make sure your presentation model and physical renderer use the define method.
You do this in Step 4 for the presentation model and in Step 5 for the physical renderer.
Log in to a Siebel client with administrative privileges.
Navigate to the Administration - Application screen, and then the Manifest Files view.
In the Files list, add the following files:
siebel/custom/recyclebinrenderer.js siebel/custom/recyclebinpmodel.js siebel/custom/carouselrenderer.js 3rdParty/jcarousel/skins/tango/skin.css files/theme-aurora.css
The file that resides in the files folder is the predefined file that you use in this example.
Administer the manifest for the physical renderer:
Navigate to the Administration - Application screen, and then the Manifest Administration view.
In the UI Objects list, specify the following applet.
| Field | Value |
| Type | Applet |
| Usage Type | Physical Renderer |
| Name | SIS Account List Applet |
In the Object Expression list, add the following expression. The physical renderer uses this expression to render the applet in a desktop platform.
| Field | Value |
| Expression | Desktop |
| Level | 1 |
| Field | Value |
| Type | Applet |
| Usage Type | Presentation Model |
In the Object Expression list, add a record with no value in the Expression field.
In the Files list, add the following file:
