Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Configuring the Workflow Process >
Configuring an Inbound Siebel Connector for ACORD XML
For an inbound message, one that originates in an external application, Figure 7 shows the structure of a workflow that receives a request and sends back a response. The example workflow is the ACORD Server Policy Package Workflow included in the sample workflows.
Figure 7. ACORD Server Policy Package Workflow
NOTE:  The error handling conditions and business services on the right side of the diagram are necessary to handle any rare processing errors. The sample workflow provides information about how they are configured.
Adding Process Property Values
You need to create Process Property values for the workflow, to be used in later configurations.
To create process properties
  1. Click the Process Properties tab.
  2. Enter the values shown in Table 27.
Table 27. Process Property Values for the Example Workflow
Name
Data Type
Default String
<Value>
String
<Value>
ACORD Client Application Name
String
ACORD Client Application Operation
String
Oracle
ACORD Client Application Version
String
8.0
ACORD DOCTYPE
String
ACORD DispMap Integration Object Name
String
ACORDDispMap
ACORD Envelope Integration Object Name
String
Newdefault
ACORD Service Provider Name
String
Siebel Partner
ACORD Signoff
String
FALSE
Error Code
String
Error Message
String
IsClient
String
FALSE
Object Id
String
PropSet Converter Out (Incoming)
Hierarchy
PropSet Converter Out (Outgoing)
Hierarchy
PropSet DTE Out (Incoming)
Hierarchy
PropSet DTE Out (Outgoing)
Hierarchy
PropSet Dispatcher Out (Incoming)
Hierarchy
PropSet TransMgr Out (Outgoing)
Hierarchy
PropSet XML Converter Out (Incoming)
Hierarchy
SiebelFINSOperation
String
SignonRsEcho
Hierarchy
XML Document Response
String
Configuring an XML Hierarchy Converter (Incoming)
The first connector component in the inbound sequence is a hierarchy converter. For information about Siebel hierarchy converters, see XML Reference: Siebel Enterprise Application Integration.
To configure an XML hierarchy converter
  1. Name the hierarchy converter appropriately (it must be unique within the workflow).
  2. Choose the type of business service from the multi-value group (MVG) window.
    For this component, choose the XML Hierarchy Converter.
  3. Choose the method.
    This example uses the XML Document to XML Hierarchy method because, for an incoming message, the conversion is from an XML document to an XML hierarchy that can be used by the FINS ACORD XML Dispatcher.
  4. Set the input and output arguments, XML Hierarchy name, and XML document name.
    The following are the input argument settings for the example hierarchy converter incoming configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    XML Document
    Process Property
    <Value>
    String
    The following are the output argument settings for the example hierarchy converter incoming configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Hierarchy
Configuring the FINS ACORD XML Dispatcher (Incoming)
The second connector component is the dispatcher.
To configure the dispatcher
  1. Name the dispatcher appropriately (it must be unique within the workflow).
    For this component, choose the FINS ACORD XML Dispatcher.
    The example uses the Dispatch Message method.
  4. Set the input and output arguments.
    The following are the input argument settings for the example dispatcher incoming configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    DispatcherMapName
    Process Property
    String
    XMLEnvIntObjectName
    Process Property
    String
    XML Property Set
    Process Property
    PropSet XML converter Out (Incoming)
    Hierarchy
    The following are the output argument settings for the example dispatcher incoming configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Property Set
Configuring the FINS ACORD XML Converter (Incoming)
The third connector component is the converter.
To configure the converter
  1. Name the converter appropriately (it must be unique within the workflow).
    For this component, choose the FINS ACORD XML Converter.
    The example uses XMLPropSetToPropSet, because the converter is converting an XML property set from the dispatcher into a Siebel-hierarchy-based property set.
    The following are the input argument settings for the example converter incoming configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    IsClient
    Process Property
    IsClient
    String
    XMLEnvIntObjectName
    Process Property
    ACORD Envelope Integration Object name
    String
    XML Property Set
    Process Property
    Hierarchy
    The following are the output argument settings for the example converter incoming configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Property Set
    SignonRsEcho
    Output Argument
    SignonRsEcho
Configuring the FINS ACORD XML Data Transformation Engine (Incoming)
The fourth connector component is the data transformation engine (DTE).
To configure the DTE
  1. Name the DTE appropriately (it must be unique within the workflow).
    For this component, choose the FINS ACORD XML DTE.
    The example uses the Transform to Siebel Hierarchy method because the data is moving from an external system to a Siebel internal system.
    The following are the input argument settings for the example DTE incoming configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    XML Property Set
    Process Property
    Hierarchy
    The following are the output argument settings for the example DTE incoming configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Property Set
Configuring the FINS ACORD Transaction Manager
The fifth connector component is the transaction manager.
To configure the transaction manager
  1. Name the transaction manager appropriately (it must be unique within the workflow).
    For this component, choose the FINS ACORD XML Transaction Manager.
    The example uses the Execute Transaction method because the data is being received from the external data source and must be delivered to the Siebel application.
  4. Establish the input and output arguments.
    The following are the input argument settings for the example transaction manager configuration. Notice that the data flow within the connector changes direction at this point from incoming to outgoing.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    Only product Integration Object Instance
    Literal
    true
    Report Error in Message
    Literal
    true
    Rollback In Error
    Literal
    false
    SiebelFINSOperationOut
    Process Property
    Siebel FINS Operation
    String
    Status Object
    Literal
    true
    XML Property Set
    Process Property
    Hierarchy
    The following are the output argument settings for the example transaction manager configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Property Set
Configuring the FINS ACORD XML Data Transformation Engine (Outgoing)
The sixth connector component is the data transformation engine (DTE).
    The example uses the Transform to External Hierarchy method because the data is moving from the Siebel internal system to an external system.
    The following are the input argument settings for the example DTE outgoing configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    XML Property Set
    Process Property
    Hierarchy
    The following are the output argument settings for the example DTE outgoing configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Property Set
Configuring the FINS ACORD XML Converter (Outgoing)
The seventh connector component is the converter.
    The example uses PropSetToXMLPropSet because the converter is converting a property set from the DTE into a standard XML property set.
    The following are the input argument settings for the example converter outgoing configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    Process Property
    String
    Client Application Organization
    Process Property
    ACORD Client Application Organization
    String
    Process Property
    String
    Is Client
    Process Property
    IsClient
    String
    Is Signoff
    Process Property
    ACORD Signoff
    String
    Process Property
    String
    SignonRsEcho
    Process Property
    SignonRsEcho
    Hierarchy
    XMLEnvIntObjectName
    Process Property
    String
    XML Property Set
    Process Property
    Hierarchy
    The following are the output argument settings for the example converter outgoing configuration.
    Property Name
    Type
    Value
    Output Argument
    Output Argument
    XML Property Set
Configuring an XML Hierarchy Converter (Outgoing)
The eighth connector component is a hierarchy converter. For information about Siebel hierarchy converters, see XML Reference: Siebel Enterprise Application Integration.
    This example uses the XML Hierarchy to XML Document method because, for an outgoing message, the final conversion is from an XML hierarchy to an XML document that can be accepted by any XML-compliant converter at the external location.
    The following are the input argument settings for the example hierarchy converter outgoing configuration.
    Input Argument
    Type
    Value
    Property Name
    Property Data Type
    XML Header Text
    Process Property
    ACORD DOCTYPE
    String
    XML Hierarchy
    Process Property
    Hierarchy
    The following are the output argument settings for the example hierarchy converter outgoing configuration.
    Property Name
    Type
    Value
    Output Argument
    <Value>
    Output Argument
    XML Document
    This step completes the inbound workflow. The inbound ACORD XML connector can be used as the basis for any workflow that is used to receive an inbound request message.
Siebel Financial Services Connector for ACORD P&C and Surety Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
