Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Creating Integration Objects in Siebel ToolsIntegration objects define the intermediate format of the data so that it can be used by the connector components to translate between Siebel data formats and ACORD XML data formats. You use the FINS ACORD Wizard to create the envelope, internal, and external integration objects, as well as the dispatcher map. Table 23 shows the pre-setup user properties for the FINS ACORD Wizard. NOTE: You can define a new Operation KeyWord Match:X if you need to. For example, if the ACORD DTD in the future supports the delete operation, you can define Operation KeyWord Match:2 as Delete/SADelete. |
| Siebel Financial Services Connector for ACORD P&C and Surety Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
