Siebel Financial Services Connector for ACORD P&C and Surety Guide > Siebel Connector for ACORD XML > FINS ACORD XML Data Transformation Engine (DTE) > DTE Methods and ArgumentsThe FINS ACORD XML DTE methods and arguments are described in the following tables. Table 7 describes the DTE methods. Table 8 describes the arguments for the DTE methods. Table 9 provides specifications for the ToExternal method argument. Table 10 provides specifications for the ToInternal method argument. Using <MapArgs><MapArgs> is a runtime input argument used by the DTE map to match an integration map argument of an integration object map. The FINS ACORD XML DTE can take as many <MapArgs> as needed as long as each name is unique among all the <MapArgs> that are passed to the FINS ACORD XML DTE at the same time. For example, suppose that the output integration object instance has some fields mapping to a workflow process property, such as an ID field.
At runtime, the DTE replaces [&CompId] with the value of the Object ID. For some mappings, if the DTE cannot find the source field value, the DTE creates empty tags by default. To remove the empty tags, add IgnoreEmptyTag as the map argument. For complete information, see Business Processes and Rules: Siebel Enterprise Application Integration. |
| Siebel Financial Services Connector for ACORD P&C and Surety Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
