Siebel Financial Services Connector for ACORD P&C and Surety Guide > Siebel Connector for ACORD XML > FINS ACORD XML Converter >
Converter User Properties
Table 11 describes the FINS ACORD XML Converter user properties.
Table 11. FINS ACORD XML Converter User Properties
Name
Value
Description
PI_Parameter:PI_Name
<PI_Value>
PI_Parameter: is a constant prefix. PI_Name=PI_Value would be a PI name-value pair included in ACORD PI. Zero or more pairs can be defined.
Examples:
  • PI_Parameter:newfileuid
  • PI_Parameter:oldfileuid
  • PI_Parameter:version
PI_Type
ACORD
Process instruction type
XMLEnvIntObjectName
<Integration object name>
Integration object name that defines the ACORD envelope.
Siebel Financial Services Connector for ACORD P&C and Surety Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
