Siebel Financial Services Connector for IAA-XML Guide > Troubleshooting > Runtime Event Setting Issues > Workflow Process Setup for Runtime Event Support.ProblemWorkflow is not executed although event has been configured. SolutionVerify the setting for the branch type within the workflow start step. This should be "Default" unless you have defined workflow runtime event from Workflow Designer, which in this case will be "Condition". ProblemObjectId is not passed to the workflow when using Runtime Event Management to trigger the workflow. SolutionThe business object name of the workflow is not setup correctly. Please select the one desired. |
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
