Siebel Financial Services Connector for IAA-XML Guide > Troubleshooting > Integration Object Setup Issues > Inactive All Unused Integration Component FieldsProblemFINS IAA-XML Transaction Manager returns error message indicating error occurs in some component fields. SolutionInactive all unused integration component fields for internal integration objects created by the FINS IAA Wizard to solve the problem. In some cases, two or more integration component fields are based on the same table column, and causes SQL error in object manager. |
Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
