Siebel Financial Services Connector for IAA-XML Guide > Overview of Siebel Connector for IAA-XML > Architectural Overview >
Integration Objects
Integration objects are the data containers used within the Workflow environment. They represent the data structure of either a Siebel Business Object or an external application's data object. You can create integration objects with the Integration Object Builder provided in Oracle's Siebel Tools. The Integration Object Builder can create Siebel Integration Objects from Siebel Business Objects. For IAA integration process you need to select the FINS IAA Wizard as a wizard to build your integration objects. This wizard reads an IAA-XML Document Type Definition (DTD) and creates the envelope and header integration objects, the required external integration objects as well as the required internal integration objects. It then associates all of these in the rule-based dispatcher map. For details, see Configuration Roadmap. NOTE: For more information on Integration Objects, see Overview: Siebel Enterprise Application Integration and Siebel Financial Services Enterprise Application Integration Guide.
