Siebel Financial Services Connector for IAA-XML Guide > Overview of Siebel Connector for IAA-XML >
IAA-XML Standard
As for the DTD which can be used, IAA has an interface design model maintained in Rational Rose which allows you to use a generation script in Visual Basic to generate IAA-XML messages and the DTD. This script uses not only the UML model but also additional generation directives to get to the precision level required by running code. You need to license the IAA models from IAA to get access to these design models and scripts. You can view and process the generated DTD by standard DTD editors and XML tools including the FINS IAA Wizard. NOTE: For information on required version, see Siebel System Requirements and Supported Platforms on Oracle Technology Network and for more information about IAA, see www.IBM.com.
