Siebel Financial Services Connector for IAA-XML Guide > Overview of Siebel Connector for IAA-XML > Using the Siebel Connector for IAA-XML > Optional ComponentsIn addition to required components, there are optional component you may want to install to help with your integration process. These components are:
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
