Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Configuring the Data Transformation MapsOne of the steps in configuring the integration objects for your integration process is to map the components and fields in your internal integration object to the message elements in the external integration object. These maps will be used by the FINS IAA-XML Data Transformation Engine to move the data from one integration object to another. For each integration process you need to configure two maps for inbound and two maps for outbound process. These map names are in the user properties entry of the dispatcher map integration object. The map names are created by the FINS IAA Wizard when it creates the integration objects. Following four maps are the maps you need to configure for the illustration:
If you wish, you can change the map name in the user properties of the dispatcher map after configuring the data transformation map. The following procedure walks you through configuring the AddPartyRequest_ERqIRqMapIn data transformation map which is used for receiving an inbound request.
NOTE: For details on creating data maps, see Business Processes and Rules: Siebel Enterprise Application Integration. |
| Siebel Financial Services Connector for IAA-XML Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
