| Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap >  Sample IAA Policy Package
 Although the IAA Party Package was used throughout the scenario provided in this chapter, you can use the IAA Policy Package instead. The IAA Policy Package is also included in the sample database of Siebel Financial Services application. The package contains all the integration objects, the data transformation maps, and the workflows needed for the scenario.  The "FINS IAA Insurance Application" project, in Oracle's Siebel Tools, includes all the integration objects. You can list all the transformation maps in the Siebel Financial Services application with a query specification of "IAA*Policy*" in the Comments field of the Integration Object Map screen. You can also list all the workflows in Oracle's Siebel Financial Services application with a query specification of "IAA Connector" in the Group field of Workflow Processes screen.
The Policy package supports the following message sets:
SubmitApplicationRequest <for AutoPolicy>
SubmitApplicationResponse <for AutoPolicy>
SubmitApplicationRequest <for HomePolicy>
SubmitApplicationResponse <for HomePolicy>
SubmitApplicationRequest <for LifePolicy>
SubmitApplicationResponse <for LifePolicy>
InquiryFinancialServicesAgreementsRequest <for AutoPolicy>
InquiryFinancialServicesAgreementsResponse <for AutoPolicy>
InquiryFinancialServicesAgreementsRequest <for HomePolicy>
InquiryFinancialServicesAgreementsResponse <for HomePolicy>
InquiryFinancialServicesAgreementsRequest <for LifePolicy>
InquiryFinancialServicesAgreementsResponse <for LifePolicy>
