| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2015, Rev. D E52426-01 |
![]() Previous |
![]() Next |
View PDF |
An activity is a task that you perform for a contact, account, or opportunity.
The following procedures related to activities and activity management are included in this topic:
"Modifying Employee Information for an Activity"
Note: You must complete the relevant setup tasks detailed in Siebel Applications Administration Guide before using the Siebel Mobile application for Siebel Finance. |
You can display activity details by using the Activities list.
To display activity details
Tap the Side Menu icon on the application banner, and then tap Activities to display the following:
The Activities list and details for the selected activity in the right pane or work area.
A list in the left pane in which you can select the related items for activities.
Tap an activity in the Activities list.
All details for the selected activity appear below the list in the work area.
To view the related items for the selected activity, tap the following names in the list in the left pane:
Contacts. Shows the contact information for the activity. For more information, see "Modifying Contact Information for an Activity".
Employees. Shows the employee information for the activity. For more information, see "Modifying Employee Information for an Activity".
Complete the following procedure to modify activity information.
To modify activity information
Update an existing activity as follows:
Tap the record field that you want to update, and update the field value.
You might not be allowed to update all fields in the record. You must navigate away from the record to save your changes to it.
Create a new activity as follows:
Tap the plus (+) icon in the work area.
Enter the information for the new activity on the form that appears, and then save the record.
Complete the following procedure to modify the contact information for an activity.
To modify the contact information for an activity
Update an existing activity contact as follows:
Tap Contacts in the list in the left pane.
All contacts associated with the activity appear in the work area, and all details for the selected activity appear above the list in the work area.
Tap the contact that you want to update.
Add an existing contact to the activity as follows:
Tap Contacts in the list in the left pane, and then tap the plus (+) icon in the work area.
Choose the contact on the list that appears, and then tap OK.
Create a new activity contact as follows:
Tap Contacts in the list in the left pane, and then tap the double plus (++) icon in the work area.
Enter the information for the new contact on the form that appears, and then save the record.
Complete the following procedure to modify the employee information for an activity.
To modify the employee information for an activity
Update an existing activity employee as follows:
Tap Employees in the list in the left pane.
All employees associated with the activity appear in the work area, and all details for the selected activity appear above the list in the work area.
Tap the employee that you want to update.
Add an existing employee to the activity as follows:
Tap Employees in the list in the left pane, and then tap the plus (+) icon in the work area.
Choose the employee on the list that appears, and then tap OK.
