| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2015, Rev. D E52426-01 |
![]() Previous |
![]() Next |
View PDF |
A lead is a new prospect or existing customer who might become an opportunity.
The following procedures related to leads and lead management are included in this topic:
"Converting a Lead to an Opportunity"
Note: You must complete the relevant setup tasks detailed in Siebel Applications Administration Guide before using the Siebel Mobile application for Siebel Finance. |
You can display lead details by using the Leads list.
To display lead details
Tap the Side Menu icon on the application banner, and then tap Leads to display the following:
The Leads list and details for the selected lead in the right pane or work area.
A list in the left pane in which you can select the related items for leads.
Tap a lead in the Leads list.
All details for the selected lead appear below the list in the work area.
To view the related items for the selected lead, tap the following name in the left pane:
Opportunities. Shows the opportunity information for the lead. For more information, see the following:
Complete the following procedure to modify lead information.
To modify lead information
Update an existing lead as follows:
Tap the record field that you want to update, and update the field value.
You might not be allowed to update all fields in the record. You must navigate away from the record to save your changes to it.
Create a new lead as follows:
Tap the plus (+) icon in the work area.
Enter the information for the new lead on the form that appears, and then save the record.
Complete the following procedure to modify the opportunity information for a lead.
To modify the opportunity information for a lead
Update an existing lead opportunity as follows:
Tap Opportunities in the list in the left pane.
All opportunities associated with the lead appear in the work area, and all details for the selected lead appear above the list in the work area.
Tap the opportunity that you want to update.
Add an existing opportunity to the lead as follows:
Tap Opportunities in the list in the left pane, and then tap the plus (+) icon in the work area.
Choose the opportunity on the list that appears, and then tap OK.
Create a new lead opportunity as follows:
Tap Opportunities in the list in the left pane, and then tap the double plus (++) icon in the work area.
Enter the information for the new opportunity on the form that appears, and then save the record.
When you convert a lead to an opportunity, an opportunity record is automatically created for the lead using data from the lead. For more information about converting leads to opportunities, see Siebel Marketing User Guide.
To convert a lead to an opportunity
Tap the Convert link to convert the lead to an opportunity.
Note: You can convert only a lead that includes a contact. If the lead includes a prospect, then you must promote the prospect to a contact before you can convert the lead to an opportunity. |
