| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2015, Rev. D E52426-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Process of Setting Up Siebel Mobile Connected Applications".
Siebel Application Object Manager parameters must be set on every Siebel Server that will support Siebel Mobile, and for each language that must support Siebel Mobile connected applications. For more information about Siebel Application Object Manager parameters and the Siebel Server Manager, see Siebel System Administration Guide. For more information about enabling Siebel Open UI for Siebel Application Object Managers, see Siebel Installation Guide for the operating system you are using.
The Siebel Application Object Manager parameter settings shown in Table 3-2 are set by default, and are required for all Siebel Mobile connected applications.
Table 3-2 Siebel Application Object Manager Parameters for Siebel Mobile
| Parameter Name | Parameter Setting |
AppletSelectStyle |
AppletSelectStyle="Applet Select" |
EnableInlineForList |
EnableInlineForList=Never |
EnableOpenUI |
EnableOpenUI=TRUE |
EnableSIFocusTracking |
EnableSIFocusTracking=TRUE |
HighInteractivity |
HighInteractivity=TRUE |
ShowWriteRecord |
ShowWriteRecord=TRUE |
