| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2015, Rev. D E52426-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Process of Setting Up Siebel Mobile Connected Applications". The handheld components for Siebel Mobile must be enabled on the supported Siebel Server. You can enable the handheld component groups for the following Siebel Mobile connected applications on Microsoft Windows:
ePharma Mobile Object Manager (<Lang>)
Consumer Goods Mobile Object Manager (<Lang>)
Sales Mobile Object Manager (<Lang>)
Service Mobile Object Manager (<Lang>)
Finance Mobile Object Manager (<Lang>)
To enable the handheld component groups for Siebel Mobile
Log in to the Siebel Web application, and then do the following:
Navigate to the Administration - Server Configuration screen, then the Component Groups view.
Query for the HandheldSync* component group.
The following handheld component groups are returned:
HandheldSync
HandheldSyncSIS
For each of these component groups, do the following:
Select the component group, and then click the Enable button.
In the Component Group Assignments applet, click the Enable button for the required Siebel Server.
If required, go to the LifeSciences component group, and enable it as described in Step 10
NOTE: The LifeSciences component group must only be enabled if using the Siebel Pharma application. |
Stop, and then restart the Siebel Server.
