Siebel Deployment Planning Guide > Siebel Architecture Overview >
Example of User Request Flow in a Siebel Deployment
Figure 3 illustrates how a user request is processed within the Siebel Business Applications architecture. In the diagram, there are two types of load balancing:
- Web server load balancing. Web client requests are forwarded through a load balancer to multiple Web servers.
- Siebel Server load balancing. Web servers forward user requests to a third-party HTTP load balancer for distribution to Siebel Servers.
Figure 3. Generic User Request Flow in Siebel Business Applications
A typical Siebel client request flows from the user's Siebel Web Client through the system components for Siebel Business Applications and back again, according to the following general flow:
- A user performs an action that initiates a request. For example, the user clicks a link in the Site Map to navigate to a particular view. The request is generated by the Web browser and Siebel Web Client framework.
- The request goes through the network, using an existing or new HTTP connection. The request might go through a network router, proxy server, cache engine, or other mechanism.
- The Web server load balancer, if present, evaluates the request, determines the best Web server to receive the request, and then forwards the request to a Web server.
- The Web server receives the HTTP request, determines that it is a Siebel application request, and forwards the request to the Siebel Web Server Extension (SWSE) installed on the Web server.
- The Siebel Web Server Extension parses the HTTP message and generates a SISNAPI message, based on the content of the HTTP message. The SWSE also parses the incoming cookie or URL to obtain the user session ID. For Siebel Server load balancing:
- On the Siebel Server, an Application Object Manager (AOM) receives and processes the SISNAPI message. If a database query is needed to retrieve the information, then the Application Object Manager formulates the SQL statement and sends the request to the Siebel database over a database connection.
The database request uses a protocol format that is specific to the database connector.
- The database executes the SQL statement and returns data back to the Application Object Manager. The Application Object Manager forwards the message to the Web server that originated it. If you are using a third-party HTTP load balancer, then the message might go through the load balancer before reaching the Web server.
- The SWSE on the Web server receives the SISNAPI message and translates it back to HTTP. It then forwards the HTTP message to the Web server. The message is now in the form of Web page content.
- The Web server load balancer, if present, then forwards the Web page content through the original HTTP connection to the end user's Web browser.
- The Web browser and the Siebel Web Client framework process the return message and display it to the end user.
