Table 5. How Service Failures Affect the Siebel Deployment
Siebel Gateway Name Server |
Siebel Server components |
You cannot start or add any new components. Users can continue to log in and out of Siebel applications. Existing user sessions are not interrupted. Server requests continue to be processed successfully, with some exceptions, as follows. |
Server administration functions |
Unavailable. |
Siebel Product Configuration Object Manager |
You can still launch product configuration sessions, as long as the connection information has been cached. By default, the connection information is cached when the first connection is made. |
Gateway Name Server database (siebns.dat) |
This database maintains server configuration information for the Siebel Enterprise Server. If this database is corrupted or lost, then you must reinstall all of the Siebel Enterprise Server software. |
Siebel Server |
Application Object Manager components |
The Siebel application is unavailable. Siebel Connection Broker (SCBroker) failure: You cannot create new user sessions. If the SISNAPI connection between the Web server and the Object Manager fails, then the SWSE retries the connection. If, after a certain number of attempts, the connection is still not available, then the connection completely fails and the user gets an error message. Existing user sessions are unaffected by SCBroker failures. |
EAI |
Interface to external application unavailable. |
Batch components |
Loss of functionality (components such as Assignment Manager or Workflow unable to process server requests). |
Siebel File System |
Attachments |
Unavailable. |
Correspondence |
Unavailable. |
Shared user preference files |
Unavailable. |
Docking transaction files from Siebel EIM |
Unavailable. |
Siebel Email Response |
Unable to process inbound messages. Unable to send outbound messages with attachments. |
File System Manager (alias FSMSrvr) |
Components that access FSMSrvr |
Current requests fail. |
Attachments |
Unavailable. |
Web server |
Siebel Web Clients accessing Application Object Managers |
The Siebel application is unavailable to Web Clients. Mobile Web Clients are unaffected. |
EAI inbound HTTP adapter |
Unavailable. |
Siebel database |
Client access, background tasks, batch tasks |
Unable to access Siebel Business Applications. Siebel Servers cannot function. Only the Mobile Web Client is not immediately affected by a Siebel database failure. |
Batch and interactive components |
Unavailable. |
