Siebel Deployment Planning Guide > Siebel Infrastructure Planning >
Process of Infrastructure Planning
The tasks in this process help you to determine the Siebel infrastructure requirements for a production environment. Along with a production environment, you must also plan for a development environment and a test environment. Use the following tasks to plan your Siebel deployment infrastructure:
- Determining How Siebel Business Applications Are Used
- Defining Data Flows and Integration Requirements
- Determining Database Requirements
- Mapping Business Requirements to Siebel Server Components
- Choosing a Load Balancing Method
- Defining High Availability Policies
- Mapping Siebel Deployment Elements to Platforms
- Determining Network Requirements
- Defining a Test and Transition Plan for the Siebel Deployment
