Siebel Deployment Planning Guide > Siebel Infrastructure Planning >
Mapping Siebel Deployment Elements to Platforms
This task is a step in Process of Infrastructure Planning. This infrastructure planning task maps the elements of the Siebel deployment to server platforms. Criteria
Mapping Siebel deployment elements to platforms must meet the following criteria:
- Guarantees adequate performance and scalability under both average and peak workloads
- Meets high-availability and resiliency goals
- Accommodates infrastructure security requirements
Requirements
Review the following information, developed in previous tasks:
Determining Server Platform Requirements
Perform the following steps to determine your server platform requirements, for topology planning: To determine server platform requirements
- Determine the amount of hardware required for Siebel Server components. Consider both average and peak workloads. Also consider background processing workloads.
On two- or four-CPU platforms, customers typically deploy one Application Object Manager on each Siebel Server. Deploying Application Object Managers in this manner is a common practice, but not a requirement. Depending on the number of concurrent users, the amount and complexity of customization and the components used, the distribution of components can vary.
For information about calculating the settings for MaxTasks, MaxMTServers and MinMTServers, see Siebel Performance Tuning Guide.
For additional help with sizing Siebel Servers, contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance from Oracle's Application Expert Services.
- Identify which Siebel Server components you can collocate. Distribute these across platforms in a way that evenly distributes workload.
Recommendations for collocating server components are provided later in this topic.
- Determine how many additional hardware platforms are needed to comply with high-availability policies.
For clustered servers, define a failover strategy for components (active-active, active-passive).
NOTE: In active-active clustering, a process is only active on one node of the cluster and is not active on the other node; that is, two physical servers are running a different clustered process.
- Identify additional hardware required to comply with security policies. For example, do you have to install additional firewalls or a proxy server? Do you have to install LDAP servers?
- Use average and peak workload information to determine how many Web servers are needed.
- Create a diagram of the Siebel deployment that shows all of the platforms and the distribution of Siebel Servers. Use the diagram to do the following:
- Verify that all of the needed server components are enabled and correctly set up on each platform.
- Run component and platform failure scenarios. Verify that there are no single points of failure that can cause unacceptable impacts.
For example, assume that you have one Web server. All of your inbound customer orders must go through it and then to one HTTP inbound adapter. If the Web server or the inbound adapter fails, then customers cannot place orders.
- Use server naming conventions to identify groups of servers that provide similar functions.
For example, in an enterprise, Application Object Managers run on one group of computers, workflows on a second group of computers, and remote user synchronization on a third group. Give the Application Object Manager servers names starting with APP, the workflow servers names starting with WF, and the Siebel Remote servers names starting with REM.
The servers in each group are displayed together in Server Manager, which simplifies server administration.
NOTE: Additional considerations for server naming are provided in the Siebel Installation Guide for the operating system you are using.
Topology Planning Guidelines
Consider the following guidelines for topology planning:
- A single Siebel Gateway Name Server can manage multiple Siebel Enterprise Servers.
- A Siebel Enterprise Server can belong to one and only one Siebel Gateway Name Server.
- A single Siebel Enterprise Server can manage multiple Siebel Servers.
- A Siebel Server can belong to one and only one Siebel Enterprise Server.
- A Siebel Server can manage multiple instances of a single server component or of multiple server components. Components can include multiple Application Object Manager types, each with their own SRF.
- The Siebel Servers in a Siebel Enterprise Server can connect to only one Siebel database.
Table 4 describes possible deployment schemes for Siebel Business Applications.
Table 4. Siebel Deployment Schemes
A single Siebel Gateway Name Server with multiple Siebel Enterprise Servers configured on a single computer or UNIX hardware partition. Each Siebel Enterprise Server has its table owner and Siebel database. |
No. If the Siebel Gateway Name Server fails, then it would adversely affect all of the Siebel Enterprise Servers. Failure of one UNIX partition could adversely affect all of the Siebel Enterprise Servers. If one Enterprise Server requires an upgrade, then all of the Enterprise Servers are affected. |
Running multiple Siebel Gateway Name Servers on a single UNIX hardware partition or on a single unpartitioned computer. |
No. This scheme is very difficult to set up. It requires manual workarounds, and requires manually editing the registry on Windows platforms. |
Multiple Siebel Enterprise Servers sharing a DBMS table owner (schema). |
Might be suitable for some deployments. There are many possible scenarios for deploying with multiple Enterprise Servers and many issues to consider. For more information, see 477829.1 (Article ID) on My Oracle Support. This document was previously published as Siebel Technical Note 544. |
Multiple Siebel Enterprise Servers, each with their own DBMS table owner and sharing the same instance of the DBMS executable. |
No. If the one database server goes down, then all of the Siebel Enterprise Servers go down. Too much dependency on one computer. |
A single Siebel Enterprise Server hosting multiple Siebel Servers within a single hardware partition. |
No. There is no additional scalability, throughput, or performance benefit to this scheme. Managing multiple Siebel Servers within a single hardware partition also requires more Siebel administrator time. |
A Siebel Enterprise Server hosting multiple Siebel Servers, with each Siebel Server on its own computer or UNIX hardware partition (multiple partitions on each UNIX server computer). |
Yes. This scheme is the most common way to deploy Siebel Business Applications. |
A single Siebel Server managing multiple applications, each Application Object Manager type having its own copy of the SRF file. |
Yes. This is a common deployment scheme. It allows you to segment functionality for each process. If multiple SRFs are used for the Object Managers in a Siebel Enterprise Server, then the SRF used for common components such as Workflow Process Manager, EAI Object Managers, and so on must have the common objects needed for proper processing. It is critical to have all of the SRF files in sync. The Siebel Repository in the production DBMS must also be in sync with the SRFs. |
Installing the Siebel Gateway Name Server, each Siebel Server, and the Siebel database all on different operating systems. |
Yes. This scheme is supported. However, it is strongly recommended to keep the deployment as simple as possible. In some cases a heterogeneous environment is required. For example, you want to install Siebel Servers running on one operating system, but a third-party product that you need only runs on another operating system. For information about supported operating systems for Siebel deployments, see the Certifications tab on My Oracle Support. |
Recommendations for Collocating Server Components
When deciding which server components to collocate, consider the following recommendations:
- Install the Siebel Document Server on a dedicated server. Siebel Document Server uses Microsoft Word to create documents. Because Word is a single-threaded process, Siebel Document Server could block other processes running on the same server.
- Consider what time of day a component is used. For example, a typical scenario is to run Siebel EIM batch jobs during off-peak hours. Doing this means Siebel EIM can be collocated with a server that is busy during peak hours. You can collocate components running off-peak with on-peak components for server consolidation purposes.
- Collocation architecture decisions are driven by the load placed on each component and the overall size of the deployment. Consider this scenario: an implementation plan involves having 1000 connected users with light Assignment Manager usage, light Siebel Workflow usage, heavy off-peak Siebel EIM batch jobs, and a moderate Communications Server load. This implementation also requires some degree of high-availability and resiliency. One possible architecture solution would be as follows:
- Clustered Gateway Name Server. Collocated Siebel File System, Assignment Manager, Workflow Monitor Agent, and Communications Server.
- Multiple, load-balanced Siebel Application Object Managers. The number of servers required depends on the level of configuration and scripting complexity.
- You can choose to engage Oracle's Application Expert Services to perform an architecture and sizing review early in the implementation process. Once key metrics are known (user count, data volume, transaction volume, interfaces, and so on), you can determine the architecture and size of the Siebel Business Applications deployment. Contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance from Oracle's Application Expert Services.
- Some components are complex to size (for example, Siebel Configurator) and require expertise to determine an appropriate architecture and distribution of components. It is always necessary to have a thorough understanding of your customizable products and how they are used.
- It is common practice in a large implementation (with thousands of users) to dedicate a server (usually a set of servers) to one function. Doing this makes it easier to monitor the performance of each segment of the implementation and makes it easier to scale each subset of the architecture. In a large implementation, Application Object Managers, Workflow, EAI, Assignment Manager and Siebel Configurator would all run on dedicated servers. The Siebel Gateway Name Server and the Web servers would also run on dedicated hardware.
- When there are more than a relatively small number of remote users (100 or so), run server components from the Siebel Remote and MobileSync component groups on a dedicated server. Planning considerations must include the total number of remote users, the expected data volume transferred between the enterprise database and the remote client, and the quantity of visibility events.
Visibility events include adding or removing a position to an account team, adding or removing a user to a position, and so on. When a visibility event occurs, it can cause a great deal of Siebel Remote activity.
It is important to identify those processes with the potential for spikes of resource consumption and spread the load accordingly.
