Developing and Deploying Siebel Business Applications > Configuring the House and Opportunity Entities > Process of Configuring the House Detail View >
Creating the Houses Screen
This task is a step in Process of Configuring the House Detail View.
After you create a view you typically add it to a screen so Siebel CRM can display it in the Siebel client. For the NREC example, you must create a new screen for houses. This screen groups the views related to the Houses entity.
To create the Houses screen
  1. Create a symbolic string for the following text:
    Houses
    For more information, see Configuring Text for Labels and Other User Interface Elements.
  2. In the Object Explorer, click Screen.
  3. In the Screens list, right-click, and then choose the New Record menu item.
  4. In the Screens list, define properties for the new record using values from the following table.
    Property
    Value
    Name
    NREC House Screen
    Project
    NREC Configuration
    Viewbar Text
    Houses
  5. In the Object Explorer, expand the Screen tree, and then click Screen View.
  6. In the Screen Views list, right-click, and then choose the New Record menu item.
  7. In the Screen Views list, define properties for the new record using values from the following table.
    Property
    Value
    Description
    Type
    Aggregate Category
    Defines a category that Siebel CRM displays in the Site Map under the Houses link. You group this and other screen views in this category.
    Category Name
    NREC
    Provides a name for the category. When you define a screen view, you choose this category name as the Parent Category for the screen view.
    Viewbar Text
    More Info
    Text that Siebel CRM displays in the Show menu.
  8. In the Screen Views list, right-click, and then choose the New Record menu item.
  9. In the Screen Views list, define properties for the new record using values from the following table.
    Property
    Value
    Description
    View
    NREC House Detail View
    Choose the name of associated view.
    Parent Category
    NREC
    Choose the NREC category to place this screen view in the category.
    Viewbar Text
    More Info
    Enter the text. Siebel CRM displays this text in the Show list in the client.
    Sequence
    20
    Enter the number. It determines the sequence in which Siebel CRM displays tabs.
  10. In the Screen Views list, locate the NREC category screen view you created in Step 7.
  11. Set the Category Default View property to NREC House Detail View.
  12. Make the NREC House Detail View the default view for the House screen:
    1. In the Object Editor, click Screen.
    2. In the Screens list, locate the NREC House Screen.
    3. Set the Default View property to NREC House Detail View.
  13. Define the page tab and screen menu items:
    1. In the Object Explorer, click Application.
    2. In the Applications list, locate the Siebel eChannel application.
    3. In the Object Explorer, expand the Application tree, and then click Page Tab.
    4. In the Page Tabs list, right-click, choose New Record, and then create a new record using values from the following table.
      Property
      Value
      Description
      Screen
      NREC House Screen
      The screen object that is associated with the page tab.
      Sequence
      125
      Determines the sequence in which Siebel CRM displays the page tabs.
      Text
      Houses
      Text that Siebel CRM displays in the page tab.
      Siebel CRM displays page tabs across the top of the client. It displays Screen Menu Items in the Site Map.
    5. In the Object Explorer, in the Application tree, click Screen Menu Item.
    6. In the Screen Menu Items list, add a new record using values from the following table.
      Property
      Value
      Description
      Screen
      NREC House Screen
      Screen associated with the Screen Menu Item.
      Sequence
      15
      Determines the sequence in which Siebel CRM displays the item.
      Text
      Houses
      Text that Siebel CRM displays as a link on the Site Map.
Developing and Deploying Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
