Developing and Deploying Siebel Business Applications > Configuring the House and Opportunity Entities > Process of Configuring the House Detail - Appraisals View >
Creating the Appraisals List Applet
This task is a step in Process of Configuring the House Detail - Appraisals View.
To display appraisal data in the Siebel client, you create a new list applet that displays a list of appraisal records for a single house record.
To create the Appraisal list applet
  1. Choose the File menu, and then the New Object menu item.
  2. In the Applets tab, click List Applet and then click OK.
  3. In the General dialog box, enter values from the following table, and then click Next.
    Property
    Value
    Project
    NREC Configuration
    Applet Name
    Display Title
    Appraisals
    Business Component
    Appraisals
    Upgrade Behavior
    Admin
  4. In the Web Layout - General dialog box, choose the templates to use, using values from the following table, and then click Next.
    Template
    Value
    Template for Base read-only mode
    Applet List (Base/EditList)
    Template for Edit List mode
    Template for Edit mode
    Applet List Edit (Edit/New/Query)
  5. In the Web Layout - Fields dialog box, choose the following fields, and then click Next:
    • Appraisal Value
    • Date
    • Name
  6. In the next Web Layout - Fields dialog box, accept the default values and then click Next.
  7. In the Finish dialog box, review the information you entered and then click Finish.
    The New Applet Wizard creates a new list applet according to the information you entered and displays the applet in Web Layout Editor.
  8. Choose the File menu, and then the Close menu item.
Developing and Deploying Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
