Developing and Deploying Siebel Business Applications > Configuring the House and Opportunity Entities > Process of Configuring the House Detail - Appraisals View >
Creating the House Detail - Appraisals View
This task is a step in Process of Configuring the House Detail - Appraisals View.
In this topic you create a new view that displays the Product Form applet and the Appraisals List applet.
To create the House Detail - Appraisals View
  1. Choose the File menu, and then the New Object menu item.
  2. In the General tab of the New Object Wizards dialog box, click View and then click OK.
  3. In the New View dialog box, enter information using values from the following table, and then click Next.
    Property
    Value
    Project
    NREC Configuration
    View Name
    View Title
    Appraisals
    Business Object
    Internal Product
  4. In the View Web Layout - Select Template dialog box, choose the View Detail (Parent with Pointer) Web template, and then click Next.
  5. In the Web Layout - Applets dialog box, choose the following applets and then click Next:
    • Product Form Applet
    • Appraisals List Applet
  6. In the Finish dialog box, review the information you entered and then click Finish.
    The New View wizard creates the applet, the necessary supporting objects, and then opens the applet in the Web Layout Editor.
  7. Choose the File menu, and then the Close menu item.
Developing and Deploying Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
