Developing and Deploying Siebel Business Applications > Configuring the House and Opportunity Entities > Process of Configuring the Opportunity Details View >
Modifying the Opportunity Form Applet
This task is a step in Process of Configuring the Opportunity Details View. To modify the Opportunity Form Applet
- In the Object Explorer, click Applet.
- In the Applets list, right-click the Opportunity Form Applet (SCW), and then choose the Edit Web Layout menu item.
- In the Web template, delete the following list columns:
- Description
- Site
- Probability %
- Close
- Organization
- Revenue
- Expected Value
- Committed
- Sales Team
- For each row in the following table, drag a Field control from the Palettes window, and then drop it in the Web template. Each row represents a separate control. Set properties for each control using values from the following table.
Agent |
Agent |
Agent |
Contact |
Contact |
Key Contact Id |
Number of Bathrooms |
Bathrooms |
Number of Bedrooms |
Bedrooms |
Price Range |
Price Range |
Price Range |
Square Feet |
SQFT |
Square Feet |
The Web template must resemble the following screen capture:
- Repeat Step 3 and Step 5 for each active applet mode.
- Save your work, and then close the Web Layout Editor.
