Developing and Deploying Siebel Business Applications > Configuring the House and Opportunity Entities > Process of Configuring the House Detail View >
Modifying the Product Form Applet
This task is a step in Process of Configuring the House Detail View. In this topic, you modify the Product Form Applet. To modify the Product Form Applet
- In the Object Explorer, click Applet.
- In the Applets list, locate the Product Form Applet.
- Choose the Tools menu, and then the Lock Project menu item.
- Change the value in the Project property to NREC Configuration.
- In the Object Explorer, expand the Applets tree, and then click Control.
- Modify the Caption property of the following predefined controls:
- Change the Caption property of the PartNum control to House ID.
- Change the Caption property of the Name control to Summary.
- In the Applets list, right-click the Product Form Applet, and then choose the Edit Web Layout menu item.
- In the Web Template, delete the controls that NREC does not require.
Use Figure 11 to determine the controls to delete.
- For each row in the following table, drag a Field control from the Palettes window, and then drop it in the Web template. Each row represents a separate control. Set properties for each control using values from the following table.
Address |
Address |
Street Address |
Bathrooms |
Bathrooms |
Bathrooms |
Bedrooms |
Bedrooms |
Bedrooms |
City |
City |
City |
Price |
Price |
Price |
Square Feet |
Square Feet |
Square Feet |
State |
State |
State |
ZIP Code |
ZIP Code |
ZIP Code |
For more information, see Adding a Field to a Form Applet.
- Drag the EditRecord control from the Controls/Columns window and drop it in an appropriate placeholder in the Web template.
- Save your work, and then close the Web Layout Editor.
