Developing and Deploying Siebel Business Applications > Guidelines for Testing a Deployment > Process of Modifying Siebel Objects > Guidelines for Integration TestingCompletion of the Functional Testing process verifies that the Siebel application functions correctly as a unit. It is recommended that you use the following guidelines during integration testing:
Figure 25 illustrates the integration testing process. |
Developing and Deploying Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
