Table 2. Integration Requirements and How They Relate to Siebel EAI
Siebel EAI Feature or Component |
Integration requirements include:
- Metadata definition
- XML metadata
- Metadata for an external application. For example, from an SAP application to an Oracle application, and so forth.
Siebel EAI features and components include:
- Integration objects based on Siebel business objects
- Integration objects based on external metadata
- Integration Object Wizard
In an integration project, you must supply metadata. Siebel applications provide XML as the common format for representing external application data. Siebel applications provide an object type in Siebel Tools, the Integration Object, and an Integration Object Wizard, which simplifies the work of creating an integration object. |
- Data transformation
- Data transformation mapping through declarative configuration
- High performance transformation engine
Siebel EAI allows you to define the type of data to exchange, and allows you to export an XSD or a DTD for a Siebel integration object. |
- Business process coordination
- Siebel Workflow Process Designer
- Workflow Process Manager
For more information, see Business Process Coordination with Siebel Workflow. |
- Transport mechanisms for interfacing with other technologies
Siebel EAI features and components include transport adapters, such as:
- IBM MQSeries
- Microsoft MSMQ
- HTTP
- Java Message Service
For more information, see Transport Mechanisms. |
- High volume data exchange
- Enterprise Integration Manager (EIM)
For more information, see High Volume Data Exchange. |
- Standards based Integration mechanisms
- XML as a format for data exchange
- COM programmatic interfaces
- Programmatic interfaces based on Java
- HTTP as a transport protocol
Not applicable. |
