Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > Validating Integration ObjectsWhen you have created your integration object and made the necessary modifications to meet your business requirements, you must validate it. This task is a step in Process of Creating Integration Objects. To validate your integration object
NOTE: After validation, the integration objects you create in Siebel Tools must be compiled into the SRF file. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
