Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > Guidelines for Configuring Integration ObjectsAfter you create your integration object you can configure it based on your business requirements. The following is a list of guidelines for configuring an integration object:
This task is a step in Process of Creating Integration Objects. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
