Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > Creating an Integration Object Based on Another Root Business ComponentThe Integration Object Builder wizard, using the EAI Siebel Wizard, allows you to choose which business object to use. However, the Integration Object Builder wizard will generate the Primary Business Component as the root Integration Component. If it happens that the business object contains multiple root business components (note the difference between root and primary business component), and that the user requires the Integration Object to be created based on another root business component, then you perform the following procedure. To create an integration object based on another root business component
Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
