Table 2. Integration Object Terminology
Component |
A constituent part of any generic object. |
Field |
A generic reference to a data structure that can contain one data element. |
Integration message |
A bundle of data consisting of two major parts:
- Header information that describes what will be done with or to the message itself
- Instances of integration objects; that is, data in the structure of the integration object
Integration object |
An integration object of any type, including the Siebel integration object, the SAP BAPI integration object, and the SAP IDOC integration objects. |
Integration object instance |
Actual data, usually the result of a query or other operation, which is passed from one business service to another, that is structurally modeled on a Siebel integration object. |
Metadata |
Data that describes data. For example, the term data type describes data elements such as char, int, Boolean, time, date, and float. |
Siebel business component |
A Siebel object type that defines a logical representation of columns in one or more database tables. A business component collects columns from the business component's base table, its extension tables, and its joined tables into a single structure. Business components provide a layer of abstraction over tables. Applets in Siebel Business Applications reference business components; they do not directly reference the underlying tables. |
Siebel business object |
A Siebel object type that creates a logical business model using links to tie together a set of interrelated business components. The links provide the one-to-many relationships that govern how the business components interrelate in this business object. |
Siebel integration object |
An object stored in the Siebel repository that represents a Siebel business object. |
Siebel integration component |
A constituent part of a Siebel integration object that represents a Siebel business component. |
Siebel integration component field |
A data structure that can contain one data element in a Siebel integration component. Represents a Siebel business component field. |
