Integration Platform Technologies: Siebel Enterprise Application Integration > Predefined EAI Business Services >
Table 52 presents the predefined Siebel EAI business services.
Table 52. Predefined EAI Business Services
Business Service
Class
Description
EAI BTS COM Transport
CSSEAIBtsComService
EAI Siebel to BTS COM Transport.
EAI Data Transformation Engine
CSSDataTransformationEngine
EAI Data Transformation Engine (DTE). For information, see Business Processes and Rules: Siebel Enterprise Application Integration.
The display name for this business service is EAI Data Mapping Engine.
EAI Dispatch Service
CSSEAIDispatchService
Dispatch Service. For information, see Business Processes and Rules: Siebel Enterprise Application Integration.
EAI DLL Transport
CSSDllTransService
EAI DLL Transport. For information, see Transports and Interfaces: Siebel Enterprise Application Integration.
EAI HTTP Transport
CSSHTTPTransService
EAI HTTP Outbound Transport. For information, see Transports and Interfaces: Siebel Enterprise Application Integration.
EAI Import Export
CSSEAIImportExportService
EAI Import Export Service. Imports integration objects from, or exports them to, XML files.
NOTE:  This business service is intended only for Siebel user interface sessions in the Siebel Web Client or Siebel Mobile Web Client. For information on converting integration objects to and from XML files, see the chapter on Siebel XML converters in XML Reference: Siebel Enterprise Application Integration.
EAI Integration Object
to XML Hierarchy Converter
CSSEAIIntObjHierCnvService
EAI Integration Object Hierarchy (also known as SiebelMessage) to XML hierarchy converter service. For information, see XML Reference: Siebel Enterprise Application Integration.
EAI MIME Doc Converter
CSSEAIMimeService
MIME Document Conversion Service. For information, see Siebel EAI and File Attachments.
EAI MIME Hierarchy Converter
CSSEAIMimePropSetService
EAI MIME Hierarchy Conversion Service. For information, see Siebel EAI and File Attachments.
EAI MQSeries Server Transport
CSSMqSrvTransService
EAI MQSeries Server Transport.
EAI MSMQ Transport
CSSMsmqTransService
EAI MSMQ Transport.
EAI Null Envelope Service
CSSEAINullEnvelopeService
EAI Null Envelope Service. For information, see XML Reference: Siebel Enterprise Application Integration.
EAI Query Spec Service
CSSEAIQuerySpecService
Used internally by the EAI Siebel Adapter to convert the SearchSpec method argument as a string to an Integration Object Instance that the EAI Siebel Adapter can use as a Query By Example object.
EAI Siebel Adapter
CSSEAISiebelAdapterService
EAI Siebel Adapter. For information, see EAI Siebel Adapter Business Service.
EAI Transaction Service
CSSBeginEndTransactionService
EAI Transaction service for working with Siebel transactions, such as begin and end, to find out whether in transaction.
EAI UI Data Adapter
CSSEAIUDAdapterService
EAI UI Data Adapter. For information, see EAI UI Data Adapter Business Service.
EAI XML Converter
CSSEAIXMLCnvService
Converts between XML and EAI messages. For information, see XML Reference: Siebel Enterprise Application Integration.
EAI XML Read from File
CSSEAIXMLPrtService
Reads an XML file and parses to a property set. For information, see XML Reference: Siebel Enterprise Application Integration.
EAI XML Write to File
CSSEAIXMLPrtService
Prints a property set to a file as XML. For information, see XML Reference: Siebel Enterprise Application Integration.
EAI XML XSD Generator
CSSEAISchXSDService
Used to generate an XSD file from an integration object.
EAI XSD Wizard
CSSXMLSchemaWizard
Used to create integration objects based on XSD files.
EAI XSLT Service
CSSXSLTService
EAI XSL Transformation Service.
Supports the Apache Xalan API as the XLST processor and Xerces as the XML parser.
Read CSV File
CSSCsvParserService
Converts a CSV file to a property set, and can then convert the property set to XML.
Siebel Message Envelope
CSSEAISMEnvelopeService
EAI Siebel Message Envelope Service. For information, see XML Reference: Siebel Enterprise Application Integration.
XML Converter
CSSXMLCnvService
Converts between XML documents and arbitrary Property Sets. For information, see XML Reference: Siebel Enterprise Application Integration.
CSSXMLCnvService
Converts between XML documents and XML Property Set or Arbitrary Property Set. For information, see XML Reference: Siebel Enterprise Application Integration.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
