Table 37. EAI UI Data Adapter Business Service Method Arguments
BusObjCacheSize |
Business Object Cache Size |
Maximum Number of Business Objects that can be cached at one time. |
ExecutionMode |
Execution Mode |
Used to set the direction of a query on a business component. Valid values are ForwardOnly and Bidirectional. The default is Bidirectional. ForwardOnly is more efficient than Bidirectional, and is recommended in cases where you must process a large number of records in the forward direction only (such as for report generation). For operations that are likely to return more than 10000 records, use ForwardOnly to avoid errors. For more information on executing queries, see the topic on the ExecuteQuery business component method in Siebel Object Interfaces Reference. |
LOVLanguageMode |
LOV Language Mode |
Indicates whether the EAI UI Data Adapter must translate the LOV value before sending it to the object manager. Valid values are LIC or LDC. If LIC is specified, then the EAI UI Data Adapter expects language independent values in the input message and translates them to language dependent values (based on the current language setting) before the request is sent to the object manager. If LDC is specified, then the EAI UI Data Adapter does not translate the value before sending it to the object manager. |
NamedSearchSpec |
Predefined Query |
Name of a PDQ. The EAI UI Data Adapter sets the name of the PDQ on the business object instance. If NamedSearchSpec and QBE are specified, then NamedSearchSpec is used. |
NewQuery |
New Query |
Default is False. Boolean indicating whether a new query will be executed. If set to True, then a new query is executed flushing the cache for that particular integration object. |
NumOutputObjects |
Number of Output Integration Objects |
Number of Integration Objects output |
OutputIntObjectName |
Not applicable |
The name of the integration object that will be sent in the output. |
SiebelMessage |
Siebel Message |
Input or output integration object instance. |
ViewMode |
View Mode |
Visibility algorithm used in addition to a search specification to determine which records will be retrieved. The ViewMode method argument is used to set the View Mode property for all business components corresponding to the integration object. Valid values are Manager, Sales Rep, Personal, Organization, Sub-Organization, Group, Catalog, and All. |
