Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter Business Service > EAI Siebel Adapter Business Service Methods > Execute MethodThe Execute method can be specified on the EAI Siebel Adapter to perform combinations of various operations on components in an integration object instance. This method uses the following operations:
NOTE: A none operation is equivalent to operation sync. These operations perform the same tasks as the related methods. For example, the delete operation makes the EAI Siebel Adapter delete the business component record matched to the particular integration component instance. However, what will be done to the children depends on the combination of the parent operation and the child operation. For information, see Table 15. NOTE: The operation method names are case sensitive. If you misspell an operation method, then the EAI Siebel Adapter assumes the default operation. An XML document sent to a Siebel application can include operations that describe whether a particular data element must be inserted, updated, deleted, synchronized, and so on. These operations can be specified as an attribute at the component level. They cannot be specified for any other element. The following XML example demonstrates using the upsert and delete operation to delete a particular child record without updating the parent: <SiebelMessage MessageId="" MessageType="Integration Object" IntObjectName="Sample Account"> <Name>A. K. Parker Distribution</Name> <Location>HQ-Distribution</Location> <Organization>North American Organization</ Organization> <CurrencyCode>USD</CurrencyCode> <Description>This is the key account in the AK Parker Family</Description> <HomePage>www.parker.com</HomePage> <LineofBusiness>Manufacturing</LineofBusiness> <JobTitle>Senior Mgr of MIS</JobTitle> <PersonalContact>N</PersonalContact> <Account>A. K. Parker Distribution</Account> <AccountLocation>HQ-Distribution</AccountLocation> About Execute Method OperationsSpecify an attribute named operation, in lowercase, to the component's XML element. The legal values for this attribute are upsert, sync, delete, query, update, insert, updatesync, insertsync, skipnode, skiptree, and none. If the operation is not specified on the root component, then the sync operation is used as the default. NOTE: Specifying an operation within the ListOf tag is not supported. For information on the ListOf tag, see XML Reference: Siebel Enterprise Application Integration. Each child node inherits the operation from the parent if another operation is not explicitly specified. If another operation is explicitly specified, then Table 15 represents the results of the operation on the current node. Example of a Parent Node Using a Sync OperationThis example demonstrates the effects of records after a sync operation is performed. Table 16 is a high level representation of a parent node using the sync operation of the Execute method. Record in DatabaseThe following code represents GENCOMM0 and GENCOMM1 being retrieved as the contacts for this example: <?xml version = "1.0" encoding = "UTF-8"?> <?Siebel-Property-Set EscapeNames="false"?> <SiebelMessage MessageId = "1-2QY5" IntObjectName = "EAI Account" MessageType = "Integration Object" IntObjectFormat = "Siebel Hierarchical"> <AccountStatus>Active</AccountStatus> <CurrencyCode>USD</CurrencyCode> LanguageCode>ENU</LanguageCode> <Location>San Francisco, CA</Location> <FirstName>GENCOMM0</FirstName> <Organization>Default Organization</Organization> <FirstName>GENCOMM1</FirstName> <Organization>Default Organization</Organization> Integration Object InstanceThe following code represents the sync operation acting on the contacts from the database. <?xml version = "1.0" encoding = "UTF-8"?> <?Siebel-Property-Set EscapeNames="false"?> <SiebelMessage MessageId = "1-2QY5" IntObjectName = "EAI Account" MessageType = "Integration Object" IntObjectFormat = "Siebel Hierarchical"> <AccountStatus>Inactive</AccountStatus> <CurrencyCode>USD</CurrencyCode> <LanguageCode>ENU</LanguageCode> <Location>San Francisco, CA</Location> <FirstName>GENCOMM1</FirstName> <Organization>Default Organization</Organization> <FirstName>GENCOMM2</FirstName> <Organization>Default Organization</Organization> Result Record in DatabaseThe following code represents the results of the sync operation after acting on the two contacts from the database. <?xml version = "1.0" encoding = "UTF-8"?> <?Siebel-Property-Set EscapeNames="false"?> <SiebelMessage MessageId = "1-2QY5" IntObjectName = "EAI Account" MessageType = "Integration Object" IntObjectFormat = "Siebel Hierarchical"> <AccountStatus>Inactive</AccountStatus> <CurrencyCode>USD</CurrencyCode> <LanguageCode>ENU</LanguageCode> <Location>San Francisco, CA</Location> <FirstName>GENCOMM1</FirstName> <Organization>Default Organization</Organization> <FirstName>GENCOMM2</FirstName> <Organization>Default Organization</Organization> In this case, if a matching Account1 exists in the database, then the EAI Siebel Adapter will perform an update of that record. If no record matching Account1 exists, then the EAI Siebel Adapter will insert a new account. For all the matching child contacts, the sync operation is inherited. Therefore, if the child exists, then it will be updated. If the child does not exist, then it is inserted. Any child contacts that exist in the database but do not match the integration object instance (unmatched children) are deleted. The reason for this logic is that the sync operation makes the record in the database look like the integration object instance. Example of a Parent Node Using an Update OperationThis example demonstrates the effects of records after an update operation is performed. Table 17 is a high level representation of a parent node using the update operation of the Execute method. NOTE: The examples represented by Table 17, Table 18, and Table 21 basically have the same result. However, as reflected in Table 20, the children do not automatically inherit Update if it is only set for the root. In this case, if a record matching Account1 exists in the database, then the EAI Siebel Adapter updates that specific record. If no matching account exists, then the result of the EAI Siebel Adapter is an error with this message: Insert operation on integration component 'Account' failed because a matching record in business component 'Account' with search specification '[Name] = "GenComm" AND [Location] = "San Francisco, CA"' was found (SBL-EAI-04383) For all the matching child contacts, the update operation is inherited. Therefore, if the child exists, then it will be updated. If the child does not exist, then it is inserted. For child contacts that exist in the database but do not match the integration object instance, they will be deleted. These might be child contacts created or associated with the Account by default. This is very similar to the previous example except the record must exist in the database. Example of a Parent Using an Update Operation and One More Child Using an Insert OperationThis example demonstrates the effects on records after an update operation acts on the parent, and an insert operation acts on one of the children records. Table 18 is a high level representation of this example. In this case, if a record matching Account1 exists in the database, then the EAI Siebel Adapter updates that record. If no record matching Account1 exists, then the result from the EAI Siebel Adapter is an error. You can also override the parent operation as in the case for Contact2. Since Contact2 does not exist, and there is an explicit insert operation, it will be inserted. Any unmatched children will be deleted as part of the parent operation (update). This is the reason why Contact0 is deleted. If you are explicitly overriding the parent operation, then you must make sure the operation applies. For example, the two combinations in Table 19 and Table 20 will fail. In Table 19, it fails because an insert is attempted when Contact1 already exists in the database. In Table 20, the update fails because SubContact3 inherits from Contact2's operation, and Subcontact3 does not exist in the database. Example of a Parent Using the Update Operation and One More Child Using the Upsert OperationThis example demonstrates the effects of records after an update operation acts on the parent, and an upsert operation acts on one of the children records. Table 21 is a high level representation of this example. In this case, if a record matching Account1 exists in the database, then the EAI Siebel Adapter updates that record. If no record matching Account1 exists, then the result of the EAI Siebel Adapter is an error. For a record matching Contact2, the upsert operation overrides the update operation. Therefore, if Contact2 exists, then it is updated. If no record matching Contact2 is found, then it is inserted. Unmatched child contacts are deleted. Example of a Parent Using the Upsert Operation and One More Child Using the Sync OperationThis example demonstrates the effects of records after an update operation acts on the parent, and a sync operation acts on one of the children records. Table 22 is a high level representation of this example. In this case, if a record matching Account1 exists in the database, then the EAI Siebel Adapter updates that record. If no record matching Account1 exists, then the EAI Siebel Adapter inserts the record. For all child contacts, the upsert operation applies. Therefore, if the child exists, then it is updated. If the child does not exist, then it is inserted. For child contacts that exist in the database, but do not match the integration object instance, they will remain unchanged because upsert does not delete children. In the case of Contact2, which has the sync operation overriding the upsert operation, it is updated, and its children are synchronized. Skiptree OperationThe whole sub tree rooted at this node is not processed. It is the same as that whole sub tree not existing in the integration object instance. Operations specified in child nodes do not affect processing in any way since the EAI Siebel Adapter does not act on the child. <?xml version="1.0" encoding="UTF-8"?> <?Siebel-Property-Set EscapeNames="false"?> <SiebelMessage MessageId="1-2RE" MessageType="Integration Object" IntObjectName="Sample Account" IntObjectFormat="Siebel Hierarchical"> <Location>cold storage</Location> <Contact operation="skiptree"> <FirstName>firstname</FirstName> <Organization>Default Organization</Organization> <PersonalContact>N</PersonalContact> <BusinessAddress operation="insert"> <AddressName>primary address</AddressName> <FirstName>firstname</FirstName> <Organization>Default Organization</Organization> <PersonalContact>N</PersonalContact> Based on this example, the account is upserted. The processing of the first contact is completely skipped although the business address child has an insert operation set. Also, the second contact is upserted. If the skiptree operation is specified for the account integration component, then the EAI Siebel Adapter skips processing the complete account. This results in no operation. It is possible to have many accounts with some having skiptree specified as shown in the following example. The EAI Siebel Adapter processes the trees that do not have skiptree specified. <?xml version="1.0" encoding="UTF-8"?> <?Siebel-Property-Set EscapeNames="false"?> <SiebelMessage MessageId="1-2RE" MessageType="Integration Object" IntObjectName="Sample Account" IntObjectFormat="Siebel Hierarchical"> <Account operation="skiptree"> <Location>cold storage<Location/> <Location>cold storage<Location/> Skipnode OperationSimilar to all other Execute operations, the children nodes inherit the semantics of the operation from the parent nodes. If a node has the skipnode operation set, then the EAI Siebel Adapter will skip setting field values for all children unless a child has an explicit operation set that will override. <?xml version="1.0" encoding="UTF-8"?> <?Siebel-Property-Set EscapeNames="false"?> <SiebelMessage MessageId="1-2RE" MessageType="Integration Object" IntObjectName="EAI Account" IntObjectFormat="Siebel Hierarchical"> <Account operation="skipnode"> <Location>cold storage</Location> <IntegrationId>1-123</IntegrationId> <FirstName>firstname</FirstName> <Organization operation="insert">MyOrganization</Organization> <IntegrationId>2-123</IntegrationId> <FirstName>firstname</FirstName> Based on this example, the account is skipped. However, the EAI Siebel Adapter will attempt to insert the two contacts. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
