Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components >
Examples of the Incoming XML Format
Table 44 contains examples of XML documents that are sent from an external system to the XML Gateway in response to a request. These examples are based on the Siebel eScript example in Custom Business Service Examples. See DTDs for XML Gateway Business Service for examples of the DTDs that correspond to each of these methods.
Table 44. Incoming XML Tags and Descriptions
Method
Format of the XML Stream
Description
Delete Return
<siebel-xmlext-delete-ret />
siebel-xmlext-delete-ret.
Only the XML stream tag is returned.
Error
<siebel-xmlext-status>
<status-code>4</code>
<error-field>Name</error-field>
<error-text>Name must not be empty</error-text>
</siebel-xmlext-status>
Format of the XML stream expected by the Siebel application in case of an error in the external application. If the error is specific to a field, then the field name must be specified.
The tags for this XML stream, and the entire XML stream, are optional:
  • siebel-xmlext-status
    This tag is used to check the status returned by the external system.
  • status-code
    This tag overrides the return value.
  • error-text
    This tag specifies textual representation of the error, if it is available. This tag appears in addition to the standard error message. For example, if the Siebel application attempts to update a record in the external system with a NULL Name, and this is not allowed in the external system, then the error text is set to: "Name must not be empty."
Init Return
<siebel-xmlext-fields-ret>
<support field="AccountId"/>
<support field="Name"/>
<support field="Phone"/>
<support field="Location"/>
<support field="AccessId"/>
</siebel-xmlext-fields-ret>
The fields-ret XML stream return contains the list of VBC fields supported by the external application for this instance.
The following field names are reserved by the Siebel application, and must not appear in this list:
  • Id
  • Created
  • Created By
  • Updated
  • Updated By
Insert Return
<siebel-xmlext-insert-ret>
<row>
<value field="AccountId">1-6</value>
<value field="Name">Max Adams</value>
<value field="Phone">(398)765-1290</value>
<value field="Location">Troy</value>
<value field="AccessId">146</value>
</row>
</siebel-xmlext-insert-ret>
If the remote system has inserted records, then they can be returned to be reflected in the business component in an insert-ret XML stream in the row tag format as the insert-ret stream.
PreInsert Return
<siebel-xmlext-preinsert-ret>
<row>
<value field="Location">San Jose</value>
</row>
</siebel-xmlext-preinsert-ret>
Returns default values for each field, if there is any default value.
Query Return
<siebel-xmlext-query-ret>
<row>
<value field="Name">Sara Chen</value>
<value field="Phone">(415)298-7890</value>
<value field="Location">San Francisco</value>
<value field="AccessId">128</value>
</row>
<row>
<value field="Name">Eric Brown</value>
<value field="Phone">(650)123-1000</value>
<value field="Location">Palo Alto</value>
<value field="AccessId">129</value>
</row>
</siebel-xmlext-query-ret>
  • siebel-xmlext-query-ret
    The query-ret XML stream contains the result set that matches the criteria of the query.
  • row
    This tag indicates the number of rows returned by the query. Each row must contain one or more value tags. The attributes that appear in row tags must be able to uniquely identify the rows. If there is a unique key in the remote data source, then it appears in the result set. If not, a unique key is generated. It is necessary to identify specific rows for DML operations.
  • value
    This tag specifies the field and value pairs and must be the same for each row in the set.
Update Return
<siebel-xmlext-update-ret>
<row>
<value field="Phone">(408)234-1029</value>
</row>
</siebel-xmlext-update-ret>
If the remote system updated fields, then the fields can be returned to be reflected in the business component in an update-ret XML stream in the row tag format as the update-ret stream.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
