Table 19. EAI HTTP Transport Send and SendReceive Arguments
<Value>
User-Defined Message Text |
Input and Output data passed as a string. This is the value stored in the Value field of the property set, either input or output. If you specify the HTTPRequestBodyTemplate, then the <Value> parameter is ignored and the HTTPRequestBodyTemplate parameter is used instead. |
CharSetConversion |
Character Set Conversion for Text Data |
Character set conversion from the external system. The default is None. |
ConnectionSubsystem |
Connection Subsystem |
Subsystem containing connection parameters. |
ConverterService |
Converter Service |
Business service used to serialize and unserialize hierarchical data to raw buffer and the reverse. Must implement the DocToHier and HierToDoc methods. The default is EAI XML Converter. |
DataHandlingSubsystem |
Data Handling Subsystem |
Subsystem containing data handling parameters. |
EndOfData |
End of Data |
Output parameter whose value is True if the end of the data has been reached. |
HTTPAccept |
HTTP Accept |
Default is text/*. The explicit value for the Accept: header to override the default. Specifies the MIME types accepted by the sender. |
HTTPAllowCaching |
Allow Caching |
Default is N. By default, the responses for specific URL addresses are not cached by the EAI HTTP Transport. Set this flag to Y to enable caching. Note that this can lead to undesirable side effects, as old data from earlier requests can be exposed from the cache buffer. |
HTTPAllowPersistentCookies |
Allow Persistent Cookies |
Default is N. A session cookie is used to tie requests and logoff operations to the user session started at the login, when communicating with any session-cookie-based system. Leaving this flag set to N leaves the persistence of cookies in the control of the EAI HTTP transport, which is the default behavior. All session cookies persist in memory only as long as the current session. Session cookies are not written to disk. If you want to use persistent cookies, that is, if persistence between logins is required and you want cookies to be written to disk, then set the parameter to Y. |
HTTPCertAuthority |
HTTP Cert Authority |
The name of the authority that issues the mutual authentication certificate, in RDN (Relative Distinguished Name) format. For example: CN=ServerName123, OU=Department, O=organization, L=Location, C=Country, E=email@example.com
represents a certificate issued by Microsoft Certificate Authority running on the server ServerName123. RDN notation is case insensitive. For information about configuring client TLS authentication, see Siebel Security Guide. |
HTTPCertSerialNo |
HTTP Cert Serial No |
The mutual authentication certificate serial number, in hexadecimal format as a string without space characters in between. For example, the serial number "19 8b 11 d1 3f 9a 8f fe 69 a0" must be provided as: 198b11d13f9a8ffe69a0
Serial numbers are case insensitive. For information about configuring client TLS authentication, see Siebel Security Guide. |
HTTPContentType |
HTTP Content Type |
Default is application/xxx-form-urlencoded. The explicit value for the Content-Type: header to override the default. Specifies the type of data sent in the body of the request. |
HTTPImplicitCharsetDetection |
Implicit Character Set Detection |
Default is False. This is the implicit character set detection for incoming data. Do not set it to True for self-describing documents such as XML. If set to True, then this overrides the CharSetConversion parameter. |
HTTPLoginBodyTemplate |
Login Body Template |
Specifies the HTTP request body that is used when HTTPLoginURLMethod is POST. By putting login information into the HTTP body (as opposed to putting it into the URL) for sending, this method provides stronger security than sending the login information in the URL. Generally, the login parameters in a login query are specified in the body of the request that uses the POST method. Required for session mode only if the HTTPLoginMethod parameter is set to POST. |
HTTPLoginMethod |
Login Method |
HTTP method to be used for logging in. If no Login Method is specified, then this parameter defaults to the HTTPRequestMethod value. Required for session mode. |
HTTPLoginURLTemplate |
Login URL Template |
Template for the URL used for the login operation. This operation is separate from the request operation and assumes communication mode is session mode. If there is a separate login, then one or more request and response messages are expected. Required for session mode. |
HTTPLogoffMethod |
Log Off Method |
Defaults is HTTPLoginMethod. HTTP method to be used for logging off. Required for session mode. |
HTTPLogoffURLTemplate |
Log Off URL Template |
Template for the URL that is used for the logoff operation. This operation is separate from the request operation and assumes that the mode of communication is session mode. If it is set, then the logoff operation is completed. Otherwise, logoff is skipped. The purpose of the logoff operation is to end a session that was started with the corresponding login. Required for session mode. |
HTTPMaxIdleSeconds |
Max Idle Seconds |
Maximum number of seconds to allow connections to be idle. After the elapsed max idle time, the connection is invalidated and restarted. |
HTTPNoAutoRedirect |
No Auto Redirect |
Default is N. This means auto-redirect is enabled. Setting this parameter to Y disables auto-redirection of messages to other URLs. |
HTTPRequestBodyTemplate |
Request Body Template |
HTTP Body to use with the POST method. This overrides any request body specified in the Value field of the input property set. |
HTTPRequestMethod |
Request Method |
HTTP method to use with the data request, such as POST or GET. Required for both session and sessionless modes. |
HTTPRequestURLTemplate |
Request URL Template |
Template for the request URL, which is the address to which the data is sent or from which a response is requested. Required for both session and sessionless modes. |
HTTPSleepTime |
Sleep Time |
Default is 120000 milliseconds. The timeout interval on login, send, and logoff requests in milliseconds. |
HTTPUserAgent |
HTTP User Agent |
Default is Mozilla/4.0. The explicit value for the User-Agent: header to override the default. Specifies the name/version of the client program. |
IgnoreCharSetConvErrors |
Ignore Character Set Conversion Errors |
Ignore character set conversion errors if True. Else, propagate the errors to the caller (default behavior). |
TimedOut |
Timed Out |
True if receive timed out and no data was available. False if request completed. |
