Transports and Interfaces: Siebel Enterprise Application Integration > EAI JMS Transport > Configuring the EAI JMS Transport > About the JMS ReceiverThe JMS Receiver (alias EAIJMSRcvr) is a Siebel Server component that makes it possible for the JMS Transport to be invoked asynchronously. The JMS Receiver:
About Multithreading in the JMS Receiver ComponentThe JMS Receiver is multithreaded and operates in batch mode. (In some previous versions, this component was single-threaded and ran in the background.) A task for the JMS Receiver component starts automatically when the Siebel Server is started, where Default Tasks (alias DfltTasks) is set to 1. Otherwise, you must start tasks manually. For more information about DfltTasks, see Siebel System Administration Guide. When a JMS Receiver task is started, a main task and several worker threads are created, whose number depends on the MinWorkQThreads and MaxWorkQThreads parameters listed in Table 15. After the worker threads are created, the main task thread starts calling the specified method on the EAI JMS Transport business service in an infinite loop, until a shutdown component is signaled. At the same time, the worker threads start their own infinite loop and perform the same duties as the main thread: they call the specified method on the EAI JMS Transport business service. In effect, the ReceiveDispatchSend operation (or any method specified) is now called by multiple threads in the same task. Previously, a single sequential call to the ReceiveDispatchSend method was made in a single process. Now, the same operation happens in parallel. The thread parallelism effectively increases scalability while limiting CPU load and memory utilization. Considerations When Using MultithreadingMultithreading works best when messages are atomic; that is, their processing does not depend on the processing of other messages. The messages can be processed in parallel without conflicts. If one message is dependent on another, then the messages must be processed in the correct order. For example, you must create an account before creating a service request for it, and create an order before adding an order line item. You can use validation scripting to make sure that parents are created before children. However, creating a data architecture that does not require additional scripting will deliver a performance benefit to the end-to-end solution. About Configuring the JMS ReceiverAn instance of the JMS Receiver is configured with the parameters of a JMSSubsys named subsystem, which specify the queue or topic to listen to, and the action to be taken. The JMSReceiver task has the following three parts:
The following is an example of how an instance of the JMS Receiver can be configured and run by using the Siebel Server Manager command-line interface: create named subsystem MyJMSConnSubsys_SR for subsystem JMSSubsys with create named subsystem SiebelEcho for subsystem EAITransportDataHandlingSubsys with start task for comp JMSReceiver with For a detailed workflow example using a JMS Receiver, see Receiving, Dispatching, and Sending JMS Messages. For a discussion of named subsystems for Siebel EAI, see EAI Transports and Interfaces Overview. For more information about administering named subsystems, see Siebel System Administration Guide. |
| Transports and Interfaces: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
